Motherboard for E8400/Q9450
pISSANt
I'm finally upgrading my system and for the first time since my Celeron 400 I'm going with Intel. I'd like some input from you guys on some parts. I have an E8400 on the way and need a motherboard, HSF and Memory (4GB). I'll be using my 8800GT, HX520, HD's, etc from my existing computer.
The Some of the things I need this motherboard to have:
- HD Audio chip: Realtek 889,885,888 or comparable (I want to ditch my Audigy 2)
- Stability when overclocked, easy to get running, good support
- Ability to accept and overclock a newer Quad core processor (Q9450, Xeon etc.) should I wish to upgrade
- Room for a large HSF (This is going in my HTPC and it needs to be very quiet. I'm thinking a Ninja due to height; I only have ~6.0" of clearance)
- Boots with E8400/Xeon w/o bios flash (I don't have a spare cpu laying around)
- Preferably will boot with >1.8v memory (Don't have any yet)
- eSATA ports
Things that I DON'T need/want:
- Two PCI-e slots (I don't ever see myself going dual vcards)
- Legacy ports/connections (serial port etc.), although one IDE port would be nice just in case...
Here's some of the boards I'm considering:
- GIGABYTE GA-EP35-DS3R
* I hear this is a good board, overclocks nicely, but I wonder about booting with >1.8v memory, double boot issue, standby (s3) issue
- DFI BloodIron P35-T2RL
*Don't know much about it. Looks nice.
- DFI LANPARTY DK P35-T2RS
*Really like layout and features, seems like it'd be great for overclocking. Any issues?
- ABIT IP35-E
*Cheap, and works well, but I hear it's picky about memory, double boot, and I'd have to run a beta bios.
- ABIT IP35-PRO
*Looks like a nice board, don't need 2 16x PCI-e slots, picky about memory, double boot, beta bios?, pwm issue.
- ASUS P5K-E
*Don't know much about the P5k series, I have an Asus board now that works ok
At the moment I'm leaning toward the DFI Lanparty or Gigabyte EP35-DS3R but can't decide which as they both have things I like. What do you guys think? Am I missing any good options? Any suggestions on memory?
:confused:
Update 3-29-08: I picked up a Q6600 SLACR for $189 and now need a motherboard for it. I'm still considering the same boards and want the capability to upgrade in the future to a 45nm processor. Any opinions? Anybody have any experience with the Lanparty board?
http://www.hardforum.com/showthread.php?t=1266257
Check the thread that I started above. I think it should be helpful. I'm working on find out about quads and the chip just arrived on my desk at work.
I own the DFI Lanparty Dark P35 T2RS and I'm going to throw my X3350 in it over the weekend, so I guess we'll at least know if that one works. I can't say that the X3350 will work with the stock bios, as I've flashed mine already. But I can say that my board worked with the E8400 out of the box and since you have one on the way this shouldn't be an issue.
A lot of boards come with 2 PCI-E slots. MSI's 780i board is really nice. I wish I'd gotten it instead of my EVGA one. I love my abit IP35-Pro, but I'm not sure it supports 45nm parts out of the box.
Thanks guys. I'll look through that thread Flexion. Oh I don't need/want 2 pci-e slots. I edited my original post, hopefully it's more clear now. Of the boards I listed, anybody have any preferences?
and ofcourse, a motherboard that supports the e8400 out of the box, supports the e3110 xeon also
just a notice.. hehe
The situation has changed slightly now... I couldn't resist a Q6600 for $189 from fry's. I may still want a 45nm processor in the future, but for now I need a good board for this processor and some memory.
I built (for a friend) a system with the E8400 and Gigabyte GA-EP35-DS3R. I wasn't aware there was a double boot issue ever, I guess it wasn't a problem with me. The main reason I bought it was because it was cheap and it overclocked well. I took it to 4.0 with out breaking a sweat (although the E8400 was a bit hot). In my opinion it was a great board, the colors were a bit strange, it looked like it was for a child or something, so if you had a side window that might be something to consider.
Running a DFI LanParty UT NF4 Ultra-D at the moment and I've just ordered the DFI LANPARTY DK P35-T2RS along with my E8400, etc. because I've experienced nothing but perfection from my current board and have heard so many good things about the T2RS. :) I'd go with the T2RS because it's pretty cheap for what you get and amazing. ;) /dfi-fanboyism
DFI Lanparty DK P35 T2RS runs both E8400 and X3350 (Q9450).
This board had my E8400 at 4.0GHz (500 x 8) and my X3350 at (450 x 8).
Working at Prime Stability at the speeds above. Still working on getting the X3350 to go higher, just got the chip 2 days ago. You should not have too much trouble OC'ing with this board. The board either doesn't boot or works fine. Never a single BSOD for me.
Remember YMMV. ;)
