motherboard fan
azn712
i have a nf7-s 2.0 motherboard and teh fan on there is really loud and annoying
is there any replacement for the fan something that isn't so loud
I was reading another post of yours and you said you wanted to overclock it. Your fan is loud because you are creating more heat and the fan is running faster. If you didnt overclock it yet, then I dont now whats causing it.
I would say get one of these ...and you shouldnt need to worry about a Fan at all.
But if you really need a fan/Heatsink combo..then I would suggest this
Well GL!
