Motherboard doesnt boot
Keem
My mobo doesnt boot, i've tried removing everything.. but its a no go... the fans spin a quarter of a spin and the mobo light goes red and turns off, i've checked for shorts and everything already, and it doesnt look like thats the problem... any ideas..
oh and before it used to like repeat the quarter spin and red light thing forever till i unplugged it.. now it only does it once and stays off
It just worked... then i turn it off to move around my room and the pc and now it doesnt..
Move it around goes bad sound like loose/bad cable.
Or cold solder joint (like on back of HDD where data cable plugs in)
Or, defect PSU
Usually HDD when they go dead will at least spin.
Or like the man says bad mobo.
Some mobo if fan on cpu doesnt work will not boot
Did you try mobo out of case?
Try with just cpu ram - no cards - see if HDD keeps spinning
My IC7-G had issues with its memory slots. Pull the sticks out and reseat them. Try just using one. It seems if they aren't in just right, they'd give me a problem and the system wouldn't show the POST.
