Motherboard does not recognize PCI-e cards
Hello everyone,
I am having a problem with X9DRW-iF Supermicro motherboard not recognizing PCI-e 1.0a PCI cards. I looked everywhere I could and it seems like the Sandy Bridge-E needs some tweaking to work with PCI-e 1.0 cards.
I tried the following BIOS changes:
  • ASPM: tried DISABLED, AUTO, and FORCE L0s
  • North Bridge PCI: tried Gen1, setting PCI-e setting to AUTO
  • Disabled Intel VTd
I have 4 of these servers and neither one recognizes these PCI-e cards. I checked the Supermicro manuals and it doesn't show that it's backwards compatible with PCI-e 1.0.
Can someone help me troubleshoot please?
Thank you very much.
Is there a setting for ACPI?
The PCI-e setting will most likely have to be set to Gen1.
What about any PNP OS settings? Maybe disable that if it is there.
Are these cards verified working on another machine?
What cards are they? If the have an updateable firmware, are they up to date?
Hello cyclone3d,
I do not know about ACPI but I know there is a BIOS option about ASPM (Active State Power Management) and it has the options: Disable, Auto, and Force L0s. I tried them all.
I have tried the Gen1 option, as well as trying all ASPM options -- no luck.
The ASPM setting is located in PNP section of the BIOS. That's where I tested all the options.
I have not verified these specific cards on other machines (I plan to) but I have identical cards working on older systems and they work perfectly fine. Also, there's about 8 cards across 4 identical Supermicro servers and none of them are being detected. I doubt that the cards/servers are faulty -- it's just a bug somewhere that's not letting the boards communicate with the cards.
The cards are TBS 6984 and TBS 6991, they are DVB-S tuner cards. I do not believe they are updateable but I contacted the manufacturer and I see on their forums another case of a guy who had problems with cards not being recognized on a similar SM motherboard X9.
I just got a response from Supermicro technical support suggesting I try the Gen1 option and I told them I have already tried that. The only thing left is to try the PCI cards on a different system to verify that they run. The PCI card manufacturer has found the root of the problem (http://www.tbsdtv.com/forum/viewtopic.php?f=37&t=7521) which seems to be the motherboard's startup negotiation TLS speed.
I'm out of ideas at this point and have spent a great del of money in this project. It is being delayed because the motherboard seems "too new" to work with PCI-e 1.0a cards
*sigh* I hope Supermicro doesn't let me down :( I've been a long-time customer of theirs.
Yep, i've got a X9SAE-V and am experiencing the same issues as you with my 3x HVR-2200.
They worked a charm on my X8STE but on my new mobo, they do absolutely nothing!
any updates on this?
ive got an updated bios from supermicro (build date as of 10/05) that picks up my hauppauge cards fine now, so if people would like it, please pm me and i will send it to you
