Motherboard Diagnostic\Testing Software
noid370
Anybody know of a good motherboard testing software I can get so that I can check my motherboard to see if the memory slots are functioning properly.
Just trying to find a good Diagnostics software that would help me. Thanks
If you want to do strictly memory testing, two options are memtest86+ which runs from a bootable CD and the Microsoft memory diagnostic which is on every Windows Vista and Windows 7 installation DVD.
If you're interested in more in-depth diagnostic information and burn-in testing, I'd recommend something like AIDA64 (which used to be Everest but recently just switched back with new others). It has a ton of goodies and burn-in tests as well as a bunch of benchmarks to see how your machine compares.
There's also PCWizard by the makers of CPU-Z.
