Motherboard decision...
MeathooK
I'm having trouble finding a motherboard for an A64 3000+. I want at least 3 memory slots...Gigabit lan port, possibly a good on-board sound. Via or nVidia..doesn't matter...but still at a decent price. I'd also like a working AGP/PCI lock...have any ideas?
There are many actually, but I will recommend what I have because it rules. MSI K8N Neo Platinum. You'll see some negative posts about it here and there, but all professional reviewers loved it and if you pay attention you can generally tell the people that have had troubles either aren't doing things right or just happened to get a bad board (happens to all OEMs).
How's that onboard sound? I heard really great things about the Sound Storm or something by nVidia. I've heard bad things about Realtek though...right now I have an SB Live! Value...kind of an old card. If there's a good Socket 754 board w/ soundstorm on it, let me know :)
Negative, Soundstorm is only to be found on nForce2 boards which are socket A (AthlonXP). Generic (though not necessarily sucky) onboard sound is all you will get with any socket 754 board. If you are really wanting nicer sound you will have to get an add-in card like the Audigy or one of the competitors. My two cents... I use the onboard Realtek because I just don't care about sound as much as I used to and my Audigy sits in a drawer.
I've heard alot of shit things about the MSI k8n Neo platinum board, I mean alot...Is there a safe alternative?
Seems like I've post this a lot lately. :rolleyes: so I'll just point you to other threads that have discussed it:
http://www.hardforum.com/showthread.php?t=789678
http://www.hardforum.com/showthread.php?t=789911
http://www.hardforum.com/showthread.php?t=785057
http://www.hardforum.com/showthread.php?t=726998 (notice how many use this board)
http://www.hardforum.com/showthread.php?t=787723
http://www.hardforum.com/showthread.php?t=789047
Look at it this way, whatever board you decide.... "Dude your gettin' an Athlon64!"
Keep in mind that on that A64 OC Data thread that the K8N wasn't out when it started. You'll start seeing people show up using it a bit later.
