Motherboard decision
I narrowed my search for a motherboard to Intel DG965WH or DG965RY for use with a Core 2 Duo E6750. I went to Newegg's site to look at the reviews and found a fair amount of negatives for both. I then started looking at other boards and found almost everything had a fair amount of negatives. Can this be attributed to people that don't know what they're doing or talking about, or are these boards really bad. Like everyone else, I certainly don't like the headaches involved in using problem parts, but now I'm not sure what to use. This is just a system for small business, and the boards listed provide features that I need at a good price. The currently recommended chipsets don't offer me many advantages since tweaking, etc. is not part of the game plan. Important is a serial port for a 3Com Courier, RAID, upward flexibility (CPU), memory), and imbedded audio, video and LAN are pluses. The 2 boards listed cover all the bases, and I've had little trouble with Intel boards in the past. Any thoughts?
I am running a DG965WH here currently and it is working fine. It is very stable and does what I wanted it to do.
But.... I really wanted more. :)
I will be replacing this board shortly myself because I would like to overclock this core2 and want my memory running at the speed it should be at. But since I can manually set voltages and other things... I am unable to do that on this board.
But from what you said, I am a very happy DG965WH user and what you need it to do this works fine. If you are interested , I might be able to part with mine :)
