Motherboard dead?
bc87_05
So I recently purchased a Gigabyte GIGABYTE GA-G41MT-S2PT Mobo for a new fileserver/downloader PC. I paired it with 2x4 MUSHKIN 996770 DDR3 10666 ram and a Q9550. The problem is when I try to boot the computer with the RAM installed it goes for a long staggered beep during startup. Also there is no signal to my monitor from the onboard vga. I removed the RAM one by one and they still did did the long staggered beep. So my next step was to remove the RAM altogether. When I did this the PC boots but I don't get any POST beeps telling me that there is no ram installed. (This is with only the CPU connected). My gut tells me my MOBO is a dud. Would that be a correct assumption or should I try something else?
Thanks in advance for any input!:p:cool:
It could be because the memory is not compatible. If you check the manual, they do tell you what is the meaning of the long staggered beep
Actually the mobo manual doesn't tell me anything about the POST codes. I looked all over that thing. I did find some information from googling it. A long repeated beep is memory error, but shouldn't it at least beep if there is no memory installed at all? That's what confuses me. The mobo doesn't beep with only the CPU installed. :confused:
Does a MoBo even attempt to POST without RAM? I've never tried that, if it doesn't initiate POST that would explain lack of beeps. Can you get into the BIOS? You could try forcing a lower mem clock and longer timings to coax the board to play nice with the RAM. Barring that, you should try different sticks if you can get your hands on some before you write off the board.
That thought had crossed my mind. The problem is that I was using the onboard vga and nothing would show up on my monitor or tv with either configuration [with or w/o RAM]. I don't have an extra GPU laying around so I wasn't able to test if that was the case. If something just showed up on the screen I might've been able to troubleshoot some more. I was also under the impression that it would at least beep at me for missing memory, that is why i tried the boot without RAM. I did however test with a known working PSU so I found that that was not the problem. Another weird thing I found yesterday was that there was no power LED on the board.:eek: I thought that was weird. :confused:
You could also try removing cpu, inspect the land grid contacts and reinstall. It bodes ill that you aren't seeing anything through the onboard gpu at all through.
Yeah, I thought it was odd that no signal was coming from the onboard. Anyways I filed an RMA and will be sending it out on Monday. I decided to RMA the memory also in case that was the problem. I was debating whether to buy a cheap 775 CPU thats known to be working to see if that was the problem, but I'm almost positive my old processor still works. Anyways, we shall see if that is the case when my replacements come in.
Also, I did reseat the CPU more than a couple times. The grid looked good to me, though admittedly I have pretty bad eyes. :eek:.
