Motherboard Dead?
jmackay
Just wondering what might be wrong with this new computer, everything was working well but I went to turn it on tonight and nothing... the power LED on the case stayed on, but the fans didn't seem to spin up and it didn't start (no action on the monitor).
I turned it off (held down power button until the power led turned off), took of the side of the case and tried to start it again, the cpu / back fan started up for about a second then turned off. Motherboard power light is still lit.
Is the motherboard bad or something else? Whats the best way to check everything w/o having spare parts?
The computer worked for 3 days before this problem arose, and it was working this morning when my friend was using it for work.
Corsair 520hx
Intel P35 motherboard
Q6600
ADATA 4x1GB
2x500gb HDs
2600xt
DVD Burner
If your fans spin as well and all lights turn on. One way to check if your mobo is dead is take out all your memory sticks then turn the system back on. If you do not hear any beep warnings that could be a dead mobo. If only your post isn't showing unplug your power connectors from your video card and see if you get a beep from that. recently had some same issues. It was my video card AND my mobo. Don't be alarmed thou. If its a new system and was previously working check all connections again and see if you can get those post warnings. If they don't I would lean towards a dead mobo. If there's any chance you can check the Psu I also suggest that as well. Also try to start up your pc with only the spare components to run. Like 1 ram stick, power connections, cpu and the video card only.
powersupply might be shot. if the fans dont spin up there might be an issue with the power. unplug the connectors from the powersupply to the motherboard and your hard drives and hook up a fan or two to the supply and the jump it to see if that could be the issue
check the power switch's in the back of the psu :p.... my psu always does that when i have the wrong toggle on.... also it might be your psu... try to beeps but most likly do this... take another psu if u can and test it on the board?.... if not try connecting just the psu to the mobo and the fan and nothing else see if that toggles any response out of the fans....
Thanks all.
I didn't have much time to test it last night but will go back tonight and see whats wrong. My buddy has a power supply tester that I can use.
I removed 2 sticks of ram and the video card and still got no beeps or anything on boot, I'll remove the other 2 sticks of ram and see if I can get anything if the PSU tests OK.
Hope if something died it didn't kill anything else :(
not hearing any beeps is not a good sign. f you test the psu and its all fine then most likely is you Mobo.
PSU is dead... hopefully it didn't take anything with it :(. Tester only lit up the +5 and trying to turn it on with a paperclip on ground/power only resulted in the fan spinning for a sec or so and then nothing.
Sucks having expensive hardware die this fast :mad: just waiting for a email for the rma now:eek:
