motherboard crapping out
Jeffxsee
Hello everyone!
My computer specs:
c2d e6750
gigabyte g35-ds2r matx board
4 gigz of ballistix ram pc6400
evga 8800 GTS 640mb
750 ocz gamexstream
(check sig if necessary)
My problem is that my motherboard seems to not post at certain times. I tested every part possible (video card, ram, sound card, power supply) and I originally thought it was the power supply. When I replaced the power supply I still had the same issue. My exhaust case fan currently does not spin unless I physically give it a slight touch. Its rpm is extremely low now and its connected directly to the motherboard. The computer works when I unplug and remove expansion cards and reinsert them. Does anyone think I have a motherboard problem? If so, I am probably going to purchase a P35 board for like 85-100 dollars. What I'm worried about is that if I purchase a board right now to replace my problematic board (P35), that I will be limited to upgrading newer parts in the near future. I would like to upgrade cpu chip, video card, and possibly higher ram in the near future. Any input will be appreciated!
Thank you
Have you tried unhooking the fans from the motherbaord to see if that fixes it? I have seen a few cases where the fan was bad and it was causing the board not to post.
You might also want to try reflashing and clearing the BIOS.
Thanks for the response, I have already tried reflashing and clearing CMOS. I haven't tried the removal of my exhaust fan though so I'll try that. Hope it works! *crosses fingers*
