Hi guys,
Looking at upgrade my 3 yr old gaming desktop because the CPU/motherboard frie.d I used to have an E8400 intel CPU and a cheapo motherboard. Looking to purchase either:
http://www..com/products/index.php?...0XA-UD3&manufacture=Bundle Deals&promoid=1376
or
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=1396552&Sku=B69-5431
I have the following heat sink:
http://www.scythe-usa.com/product/cpu/049/sczp2000-detail.html
I have a couple of questions (I've been out of the loop for a while). If the heatsink fits the new CPU, will there be any issues with moving from an INTEL motherboard to AMD?
The heatsink spec page doesn't list the X6 as compatible. However they don't seem to have updated that page in a while. Can anyone confirm that it won't fit? As far as I can tell, the socket is the same type.
Also, (stupid question), can I plug DDR2 (my old ram) RAM into the motherboards listed above? They only list DDR3 compatibility.
Also, if these both seem like bad upgrades, any suggestions would be great.
Thanks for any help guys.
or
