Motherboard Choice
Da Man
Hi,
Been here for years and years, but not really too active in the computer scene in the last year. My computer is showing it's age, and I have decided to do a full system upgrade. Here is my basic situation:
I build a new computer every 18-24 months, rather than upgrade piece by piece. So in that sense, I don't need a few things I have decided not to go with, such as SLI. I will be running for the next 18-24 months with this system, with most likely no upgrades. I will NOT heavily overclock, as I play older games where speed is not super important, and I do programming where I can't have the computer crashing all the time. I will prolly see if I can up the multiplier by a point, but if it's not 100% stable I will run at stock and be happy. (BTW, are Athlon 64 x2s unlocked? Seems like all cpus are unlocked these days.. lucky people :p )
AMD Athlon 64 X2 5200
4gb of DDR800 (won't upgrade, so doesn't matter if mobo support 8+)
GeForce 8800GTS (will NOT be in SLI, so don't need mobo with SLI)
other normal stuff :p
The biggest confusion I am having is what motherboard to buy. I have the past few systems bought nForce stuff and been happy, so was looking at that. NForce 4 can sometimes support socket A2, but it uses slow DDR533 or such, so that is out. Nforce 5 seems to have a bunch of different versions such as 570 and 590... but they were all SLI, and I was not seeing a difference. Can anyone point me to a good place that shows the differences between all the different motherboards? I am not seeing a big difference between $220 NForce 590s, and $120 570s. Whats the difference between all these, and can I even find a motherboard anymore without SLI?
Finally, I won't be doing any crazy FSB overclocking, so I guess DDR 800 is all I want? The DDR 900 and 1000 is strickly for overclocking I assume?
all nF590 mobos have SLI.
& we're all going to say look at Intel Core 2 Duo insted of AM2.
I used to always go Intel until around the the time Athlon moved to socket A from slot A.. then I went all AMD for the next several years..
I guess I should investigate Intel again, I see they have the definite lead in technology with a smaller nm, but that alone doesn't mean everything.
Hum let me start investigating, watch me be confused by which intel motherboard is best.
Intel Core 2 Duo E6600 is $315, about $100 more than a 2.6ghz A2. Hum does it justify that or not..
Just get a E6300 or E6400 with a Gigabyte P965-DS3, go with the same video card and memory and you'll be set. Do you plan on doing any overclocking, generic DDR800 will definitely get you to a 400 mhz fsb if not higher.
Well the only point of going Intel seems that they overclock so well. At stock, AMD is still looking a better bang / buck.
I only use the comp for 2 years at a time, so I don't have to be super-careful with it. Maybe I will see how far I can juice it. Generic DDR800 is enough you say?
If you're going AMD, I'd get 2x2GB rather than 4x1GB. The integrated memory controller doesn't like 4 dimms very much. $335 per set is a lot for DDR2 800 memory. You can get by spending closer to $235 for very good stuff and you'll probably never know the difference.
Personally, I'd go with a E6600 and a 965 board. P5B Deluxe or P5B-E. Get some Cas 4 DDR2 800 memory and you're set. If you want to OC, you can do 3.2-3.4Ghz pretty easily.
Well this is what I am looking at now. Only concern is if the heatsink will fit on the mobo, as the mobo has some weird crap under it. May need to switch to the asus board recommended above. Only thing not final is PSU, as I didn't mess around with it much. Will prolly spend $150 and get a nicer PSU.
Shopping Cart
Qty. Product Description Savings Total Price
1
Antec Solution SLK3000-B Black Steel ATX Mid Tower Computer Case - Retail
Item #: N82E16811129152
Return Policy: Standard Return Policy
-$5.00 Instant
$59.99
$54.99
2
Western Digital Raptor WD1500ADFD 150GB 10,000 RPM Serial ATA150 Hard Drive - OEM
Item #: N82E16822136012
$30.00 Mail-in Rebate
$439.98
($219.99 each)
1
PNY VCG88GTSXPB GeForce 8800GTS 640MB GDDR3 PCI Express x16 HDCP Video Card - Retail
Item #: N82E16814133188
Return Policy: Limited Non-Refundable 30-Day Return Policy
$399.99
1
Antec NeoPower NeoHE 550 ATX12V 550W Power Supply - Retail
Item #: N82E16817103941
$109.99
1
Arctic Silver 5 Thermal Compound - OEM
Item #: N82E16835100007
Return Policy: Consumable Items Return Policy
$5.99
4
OCZ 1GB 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Desktop Memory Model OCZ2P800LP1G - Retail
Item #: N82E16820227165
$479.96
($119.99 each)
1
GIGABYTE GA-965P-DS3 LGA 775 Intel P965 Express ATX Intel Motherboard - Retail
Item #: N82E16813128012
$132.99
1
ZALMAN CNPS9500 AT 2 Ball CPU Cooling Fan/Heatsink - Retail
Item #: N82E16835118003
-$15.00 Instant
$62.99
$47.99
1
* Intel Core 2 Duo E6400 Conroe 2.13GHz LGA 775 Processor Model BX80557E6400 - Retail
Item #: N82E16819115004
Return Policy: Processors (CPUs) Return Policy
* UBISOFT Ghost Recon Advanced Warfighter - OEM
Item #: N82E16800992001
-$49.99 Combo
$271.99
$222.00
Subtotal: $1,893.88
Shipping: $37.72
Grand Total: $1,931.60
People are using the Zalmans with the DS3 in the Conroe OC database, so I think you'll be ok with it fitting. Memory seems a tad bit on the high side, you can probably get it a bit cheaper if you buy 2 Gig paired sets, seems to be a bunch of rebates going on with them.
Personally, I'd hold off on buying a different heatsink if I was purchasing a retail chip until I got to the point where the stock heatsink wasn't performing well enough. But that also depends on how high of an overclock you plan on doing too.
For the hard drivers, I'd buy a raptor for the OS and then Seagate 7200.10 500 GB for the same price as the second raptor for your data.
But it looks like a solid build either way.
I wouldn't get the DS3 if you're planning on doing a RAID array. Get a board with the ICH8R rather than the ICH8. I hear the Corsair HX PSU's are nice. I'd get one of those over the NeoHE. Or even the Thermaltake Toughpower series (none of the other TT PSU's though :) ).
I already have a pair of 500 gig sata drives I run in mirror for my backups. So the raptors would be strickly for the OS and games and apps... with a weekly backup being dumped to sata drives.
So think the ICH8R is that much butter than ICH8? That is something else to investigate, hummm. I wonder if the ICH8R can handle my two different raids, a stripe for the raptors, and a mirror for the slow crappers.
Hum so if I go ICH8R for my southbridge, I need to pick P965 or G965 for my northbrige.Guess I gould go P because it is newer.. so that leads me to either a
ABIT AB9 Pro LGA 775 Intel P965 or a ASUS P5B Deluxe LGA 775 Intel P965 for my motherboard. Those seem to be the "newest" of the boards with the ICH8R.
Seems like the G965 has built in wi-fi. which is interesting. My current wi-fi station got destroyed by my cat, I wonder if I can use the built in wi-fi to server internet out to my wireless laptop.
I am having trouble picking ram still I guess. Worried about getting ram too cheap to overclock well. I can get this junk for $84 a gig.. but I don't know how useful it is. http://www.newegg.com/Product/Product.asp?Item=N82E16820211063
Well, I think the cheapest ICH8R board is the P5B-E. You can also do the ICH7R on the 975X chipset. I think MSI has a board for $150 or so and DFI's is $160. The new Abit AB9 Quad GT looks pretty sweet. I wouldn't get the AB9 Pro personally (I had one and it's ok, but I'd try the P5B-E before I got the AB9 Pro again).
That RAM doesn't look too bad...as long as it boots at 1.8V you should be fine (even if it doesn't it might boot anyway and then you just go in and set the timings yourself).
965 is definitely looking nicer the more I read up on it.
The P5B-E only has a P965.. the GP965 has my interest for the wifi port and 2nd gigabit port (saves a pci card)
Hum you guys are saving me a lot of money, usually it cost me more money when I post here :p This is what I am at now
$59.99
$54.99
2
2x Western Digital Raptor WD1500ADFD 150GB 10,000 RPM Serial ATA150 Hard Drive - OEM
$439.98
($219.99 each)
$399.99
CORSAIR CMPSU-520HX ATX12V v2.2 and EPS12V 2.91 520W Power Supply - Retail
$129.99
$5.99
4x A-DATA 1GB 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Desktop Memory Model ADQVE1A16 - Retail
$339.96
($84.99 each)
ASUS P5B Deluxe LGA 775 Intel P965 Express ATX Intel Motherboard - Retail
$178.99
$47.99
$222.0
Total: $1,859.01
- $90 mail in rebates
$1,769.01
I've actually saved enough money by going for cheapo ram, I can either go for a the top of the line video card, or maybe even a core2 quad.. although I doubt the quad overclocks as well :/
Im about to buy a ga-965p-ds3 and i run raid 0 seagates, what problems does the onboard raid controller have?
the DS3's RAID controller is the JMicron whereas the ICH8R is better (more ports & better performance)
You have to do it off of the Jmicron controller and not the Intel controller.
Edit...Oops, beat me to it.
