Motherboard causing Win XP setup to freeze? HELP!!!!!!!!!!1
takeabao
Okay so here's the deal, my buddy has a 3.0C running on an ASUS P4C800-E Deluxe bought brand new off newegg. When we got around to installing windows XP on his RAID-0 Raptor 36GB's, it gets to the point where it says "Setup is starting windows... Press 'Enter' to setup Windows....F3 to quit....or R to go into Recovery Console". And then...
It freezes. The keyboard LED goes off and the keyboard stops functioning. We've already tried using 3 different sets of RAID drivers thinking that might be the problem. Doesn't appear to be so. Also, we've tried removing all unneccesary cards/drives/etc. to no avail. We even swapped keyboards and that didn't work. So...
My instinct tells me that his board is dead? Perhaps? The hard drives are brand new and since it hasn't gotten to a point where data is being written to them, it seems unlikely that that's the problem.
Any help/advice would be gladly appreciated. Thanks in advance.
_Ray
what video card are you using? I know that I can't install windows with my geforce cards in my computer for some reason. The system hangs at Windows Setup is starting or something to that effect. It is right after the computer loads all of the files off of the cd before you accept the terms of agreement.
I ad similar problems on the same motherboard when building a machine for someone. It turned out to be ram that wasn't compatible.
Motherboards rarely go bad. Especially not ones from major manufacturers.
Wow, fixed the problem.
You won't believe this guys...turns out...it was the USB keyboard that was giving us a hard time. Who the hell would've thought that?? One reason why:
PS/2 keyboards > USB keyboards.
