Motherboard - Case compatibility
azul
I'm trying to put a p35 s series into a cm 690 and the holes don't align at all, giving me no way to screw in the motherboard.
Or do the screws go into the slightly larger holes with silvery parts around them? I don't want to kill the mobo just yet:)
The CM 690 should accept all ATX and mATX boards so I really don't know what to say. Do you have extra studs that screw in the MB tray lying around?
One of the pins/screws I had fit in perfectly. However, I am incapable of screwing in the others.
Hmm, I think I have to screw one pin into the inside wall, put on the motherboard, and then screw in another pin into the 1st. Let's try that.
Yep, that worked. God, I wish the manuals were better. Never specifically says how to screw it in.
