motherboard advice
Hikaru IchijoSL
I am looking to build a AMD system. I want a b850 board (or a low end x870). The biggest problem is the lack of 5.1 speaker support. I can't find any boards that have it.
I have a working klipsch ultra 5.1 and I am not getting rid of them.
I have been out of the loop for a long time. What options do I have.
I am still using a i7-2600. But it is time to retire it.
I am looking to build a AMD system. I want a b650 board (or a low end x870). The biggest problem is the lack of 5.1 speaker support. I can't find any boards that have it.
get an asus b650(or m), they have a spdif header or all 6 jacks.
I feel like such an idiot I wrote b650 I meant b850.
ok, asus still has quite a few with 5.1/7.1, and if they do not have the 6 jacks on the back, they will usually have the spdif header for optical 5.1($15 on amazon, i think your speakers have it...)
Thanks, do you have a good idea which optical to 5.1 i should get.
Also if it just has the 2 audio and 1 mic 3.5mm ports, the mic can be changed to audio out giving those 3 a total of 6ch output.
ah, yeah they can do that too. i keep forgetting about the "smart jacks"
i bought the official asus one but they only seem to sell those ones in canada: https://www.amazon.ca/dp/B01LWNKIKN
this one should be fine though, and technically any should work, just change the pinout to match: https://www.amazon.com/Acxico-Optical-Bracket-Gigabyte-Motherboard/dp/B0B2QQWG38
I do not have spdif on my speakers.
Pretty much all motherboards now can change input/output assignment. They should all be capable of 5.1 without issues.
I would say you should be more focused on getting a B650E or X870 board. B650/B850 aren't required to have PCI-E 5.0 connectivity.
Don't bother with onboard 5.1 sound. Just go USB. I did and I'm never going back. No performance issues with a modern rig, they sound at least as good as a similarly priced sound card, and you don't need to bother with making sure you have a slot available.
Which USB did you go for? Does it work well for headphones as well?
X670E boards, especially used, can be had a for a fraction of the relabeled X8XX ones though they are the same chip, I got my X670E plus for less than $150 back in Dec.
Just a SoundBlaster X4. I initially grabbed it because my new board didn't have 5.1 analog out so I needed something and that's what Microcenter had on the shelf. Now I'm a convert. It definitely sounds better than the onboard RealTek on my old rig. I thought about getting a card but I didn't want to use up a slot for one or restrict airflow to my vid card.
I haven't actually tried the headphone port. I basically don't use them at home.
This is same one I was looking at. https://www.amazon.com/Creative-272791-70sb181500000-Blaster-X4/. Any gaming issues/bugs etc. AI told me it has hissing sounds etc. through headphones sometimes.
Not that I've noticed but it is a Creative product with all sorts of gaming "enhancement" settings you can mess with. I'm sure there's a way to mess it up.
Final question and I will stop derailing this thread. Do I need to have creative software running in the background at all times? I remember only horrors from creative never updating their software and it causing me lots of headaches given I try most new games. Is that still true?
B850 is required to have pcie 5 for nvme but not graphics, though a lot of the 850 models add that in. X670/x870 often have price premiums over b650/850 boards even with equivalent specs, as the naming alone seems to carry the perceived upgrade vs consumers actually looking at the features.
Case in point: b850 Aorus is similarly specd to the x870 save an m2 slot and usb4, but those are features most won’t ever need. But its way cheaper, like $50-70 or ~20-30%
The Creative App has a setting to not load at startup and sound still works without it.
AMD's naming convention makes things confusing. In terms of CPU PCI-E lanes, it goes roughly something like this:
B650 = B840
B650E = X870
X670 = B850
X670E = X870E
When strictly looking at chipset PCI-E lanes and USB 3.1/3.2 ports, it goes like this:
B650 = B650E = B850 = X870
X670 = X670E = X870E
Best bang/buck AM5 boards with guaranteed PCI-E 5.0 capabilities are B650E boards IMO. AM5 should easily last several generations of PCI-E 5.0 GPUs.
I do not want to spend $142 for that external soundcard.
dont listen to the "you have to have a dac" people...
the onboard sound for that board you chose is isolated, uses decent components and is 7.1
