Motherboadr problem
lemmy
Okay everything is hooked up, now when i try to startup the computer, i can't see anything, it's like theres no power going to my pci x16 mobo slot. I hooked up the extra power cord to the vid card as needed. At first i thought it was vid card broken, so i tried antoher pci 16x vid card and still not working. Any clue whats the problem? do you guys think the mobo is dead? i see lights on and everyhthing working. It's a DFI Lanparty NF4 Ultra.
is your video card seated properly, make sure it is, and everything else, like your memory and ATX connector etc.
Also, don't forget the floppy connector near the RAM. There should be four power connections, the 24-pin ATX, the 4-pin P4 located just above the ATX, the 4-pin Molex, and the 3-pin floppy below the RAM.
everything is in properly, but i just figured out i have 4 red lights turning on inthe mobo, meaning that there is a processor problem, but even when i reseated the processor , it still is not working.
