mother board problems
DeeZNuTTss
I was changing over my motherboard and other crap. And after I finished moving everything the computer turns on for less then a sec and it’s off. I have to take out the power cord wait a few min plugs it back in and it does it again. I've tried another power supply, but the same thing happens. So I started to disconnect components that I didn't need to start the computer. But still the same thing happens. So now it’s just sitting around with just and motherboard, processor, fan, memory, video card. And power supply and still nothing but the quick little flash of my led fan and off it goes again. Any Ideas on what it could be would be great help. Thanks a million.
PoWeReD By DeeZNuTTss
Drift 240sx
Your drivers from your previous motherboard might be causing the problem. If you have same chipset as before then that should be ok. Windows is shutting down to prevent any damage to computer beccause of this. Try resetting cmos and if all else fails reformat and reinstall Windows to be safe.
i'm using all the same components. just switching cases. could it be the processor not touching the heat sink properly?
