Most 'unsolvable' crashing problem I've ever faced
antipunt1
This thread is only for those who want to tackle something relatively challenging. For months now (on and off), I've been unable to fix my mysterious video-crashing problem. Below I will list the symptoms, and then afterwards, I'll list my findings (which will explain why this is such a toughie). Help would be greatly appreciated, but like I said, this problem is probably for experts only
Symptoms:
-videos players of the nature of youtube.com, gamespot/ign.com, cannot be fullscreened without the risk of a sporadic crash (meaning it happens sometimes only, but often enough to be dangerous). First, you get colorful strips that distort the image. Once this happens I know 100% of the time when I press 'esc', the computer will freeze (become nonresponsive), forcing a restart.
-non-full-screened videos run fine. Also, any other video-format (like downloaded video files/games) have a 0% chance of running into this problem. It's specific to youtube-ish formats.
-occasionally, my computer will run into a black screen upon booting, and never get to my OS.
-sometimes upon 'sleeping' (which is automatic after 1 hour), my pc will also get a black screen, and never wake up.
Findings:
-I know it might seem Adobe Flashplayer plugin is the culprit, but it isn't. I've tested this numerous times.
-it isn't my memory, I ran memtest
-It's not my hard-drive.... because recently it crashed (probably from all the freezing/crashing). So I'm running on a new Maxtor 1TiB. After reinstalling windows, I tried full-screen on a youtube video...and the same problem occured.
-probably aren't my video cards. Like I said before, I can run games/downloaded videos 100% of the time without any sort of colorful-crashing.
-the CLOSEST answer anyone's ever given me was that it was my outdated drivers/BIOS? for my motherboard.
http://www.hardforum.com/showthread.php?t=1345363 (the bottom answers)
The thing is, I believe I've tried this already, to no avail...err.. I think anyways. I've upgraded to the latest 'drivers' for my mobo, but is this different from 'latest-bios'?
Sorry for the mess, thx for the help
PS: my specs are listed in my sig
driver's and BIOS are different.
BIOS is hardware-level. Basic Input/Output System. It's what gets the motherboard working with other components.
Drivers are the software that tells the operating system how to use the hardware.
how do you know it's not the Flash player?
Also, you say you're on a new hdd now... was it a new/fresh install of Windows, or a copy of your old install?
edit: what motherboard do you have?
"how do you know it's not the Flash player?"
mostly because I tried reinstalling the plugin multiple times. Also, the problem reoccurred on my new harddrive after the old one crashed.
"was it a new/fresh install of Windows"
yes
"edit: what motherboard do you have?"
750i Nforce
This is a documented issue I've seen before. It is a problem with NVIDIA chipsets. This can be remedied by turning SLI off when watching video. This worked for me back when I was using 680i SLI motherboards. On motherboards with Intel chipsets that support SLI I haven't had that problem. I also haven't seen that problem with every SLI system that runs an NVIDIA chipset either.
Sounds like a software problem to me. However, according to a skim of your old thread, its a known issue with NVIDIA 7-series boards and a BIOS update will fix it? So yes, update your BIOS. Your mobo manufacturer's support website will give you the needed files and instructions.
//jeez i'm slow
"This can be remedied by turning SLI off when watching video"
Hm..this actually sounds like it would work. I've had compatibility problems with SLI in the past, and I never thought about this. So I have to either choose to quarterscreen my youtube-videos or to only manually turn on SLI during video-intensive processes like gaming (and to have it off by default).
"and a BIOS update will fix it? So yes, update your BIOS"
I'm a partial noob, and have been instructed by a friend in the past that messing with BIOS is only for pros? You think this'd be safe? Also, if the BIOS isn't affected by downloading the 'driver' for the MOBO (aka they are different things), I'm officially confused because I don't see why they wouldn't include a BIOS update into the mobo-driver
PS: THANKS VERY MUCH for the help thus far. I didn't expect you guys to be so quick!
As I recall the problem was with NVIDIA 6 and 7 series chipsets when running SLI. Turning SLI off while watching video worked for me in every case.
Thx very much. I scanned some sites and it seemed that the BIOSupdate wasn't even a 100% fix! Lesson learned: next time, research the mobo in depth before actually buying it...
But thx for the SLI fix. I have a feeling it should work, and it sounds much safer than messing with BIOS
The SLI fix which Dan_D mentioned will probably work. But I had a similar problem a little while ago it was cause by a dodgy SATA header on the motherboard.
I bought a little SATA PCI card plugged my hard drive into that and everything has been sweet since.
That shouldn't matter.
So I can't be curious? :confused:
lets not start another discussion in why some one should or shouldnt be running sli in the first place..
Lets... just in case the OP is misinformed. This whole forum is for discussing things.
@OP: If you're running games at a resolution lower than 1900x1200, then you don't really need SLI. And if SLI causes you problems, and you'd rather eliminate those problems by getting rid of SLI, you can sell your old cards and get a single card instead, that will perform on par or better than your 8800GT setup. If you'd rather keep SLI, then obviously, just turn it off when watching youtube and the like. ;)
btw, I'm not a cat.
I run things at 1680x1050. I'm not exactly sure if what enginurd is getting at is legit though. LOL, in any case, it's not like I can sell my old cards for 100% buyback =P
I'm not saying you'll get 100% of your money back. All I'm saying is, you don't need SLI for your resolution. Since you already have it, what to do now is up to you.
http://www.anandtech.com/video/showdoc.aspx?i=3517
In general, more than one GPU isn't that necessary for 1920x1200 with the highest quality settings, and the Radeon 4870 1GB or an overclocked GeForce GTX 260 core 216 are good options there. Slower single cards are fine for the high quality at 1680x1050 and multiGPU options are basically wasted at this resolution and lower except in Crysis. As we've seen in past tests, only those with 30" monitors will really benefit from multiple GPUs in their system for now.
So... did the BIOS update work? Or did simply turning off SLI fix it and you didn't update the BIOS?
As an IT professional I can say, memtest is not 100%. Yes it's a great tool BUT it's not gonna catch everything. If memtest says a stick has a problem, it's most likely bad, but if memtest does not find a problem that doesn't mean the stick is good. It just means memtest couldn't find a problem. At one of my old jobs we had a $2000 ramtest machine... that thing was the shit. I built a set of 10-12 machines with some OCZ DDR2. Out of those RAM sets almost every one had a bad stick. Must have been a bad batch. Memtest was only able to detect 3-5 out of 8-9 bad sticks.
I only go into this ramble because I have seen machines with sleep problems having bad RAM. If disabling your SLI doesn't work you should try running only one stick of RAM and see if one of your sticks may be bad.
