Most Powerful 140mm Case Fan
That's a 48v fan... You'll probably want something 12v. This one is 103 CFM but I'm sure it's loud as hell haha. Of course, the fan you mentioned hits 367 CFM @ 5500RPM but at 74dB it would sound like a hair dryer haha.
Well it will be for intake, blowing on two very hot GPUs that mine constantly. So pressure is very important, cfm being a close second.
I would also like to be able to adjust the fan in some way...the Silverstone AP182 I bought for my main rig is perfect, it has a knob that attaches to a PCI bracket allowing you to turn down the fan so it is completely silent, or full blast where it is like a box fan. However that is 180mm only, and I would like a 140mm equivalent for my mid-tower.
Thanks
many high pressure fans are loud even when on 7v and most cannot start up unless they have 7v
if you buy something like this do so knowing it is going to be really loud... and there isnt a good way to change that and still get good airflow.
I would bet 50 CFM fans would do well in your situation
the perfect balance between noise and speed is the BitFenix Spectre Pro Solid White 140mm Case Fan, Affordable, Fast, Silenced and SEXXXY ;)
