Konstantinnovation
- Jun 25, 2001
I am currently trying to figure out what is wrong with my main gaming rig/workstation. Since I cannot get it to a bios screen, nor get the motherboard to beep, it is a very frustrating thing to do. It basically spins up the fans does not beep and then shuts down the fans and makes a little clicky noise from the system speaker. I unplugged everything, and rewired everything, and now it is fine. Go fig.
I don't really need tech support but some moral support in the form of some war stories would be nice.
I am just wondering what you guys have found the most frustrating things to fix on your computers? Give your worst tech issue that you worked on and fixed. (Clearly this wasn't an amazingly difficult problem to deal with since it was fixed within the hour)
