Most compact sli / tri-sli / crossfire case?
sicminded
hello,
this is my first post! i've been researching for a month now it seems in building my first pc. the one component im most indecisive on is the case. after lookin around, i had my mind set on either a tj07 or tj09. great cases, excellent for air cooling and liquid cooling options. but now i'm thinking about staying compact and i'm wondering what my options are.
what is the most compact case big enough to fit the largest gpu's in sli / tri-sli / crossfire? (like the 8800 gtx or similar). if you got pics, plz share!
thanks,
chris
A05 is Ok for my 2x 8800GTX on air, but in no way would I put another in there, its a oven as it is. You would have to look into WC for that.
would two or three 8800 gtx fit in a pc-7b?
i'm aware of the cooling issues with smaller cases, i'll try to get away with just air but will definately be doing some lcs if it is necessary.
thx,
chris
