Most accurate PSU calculator?
Rinzler
EDIT: I've decided on one, thanks for the info. :)
I'm about to build a new computer and need to decide on a PSU, I tried a few different calculators and came up with different results, from 550w to 850w.
So, my question is this; is there an accurate psu calculator?
... or if anyone wants to recommend one for this system.
1 GTX 980 Windforce --- might need 300w alone?
1 Z97X soc
1 i7 4790k --- might overclock to 4.2GHz
2 8GB 1600 RAM sticks
1 HDD
1 SSD
1 bluray drive
1 CPU fan
3 case fans
~8 USB items
I won't be overclocking the RAM or the GPU(outside of factory OC). And no sli/crossfire in this computer's future.
Thanks in advance!
Personally I don't trust any of the "calculators" as they're basically all inaccurate in my experience. My system runs around 350W at full tilt, the "calculators" say 500+ easy.
I'd aim for something in the 600W range, it'll be enough and still give you plenty of headroom.
The 980 doesn't require 300W on it's own. People keep mis-reading the reviews. That's ~300W pulled for the machines AT THE WALL. See the config in my sig, I'm rolling perfectly fine with a Seasonic Platinum 520W.
A 500 watt power supply would be more than sufficient for your system.
The most accurate PSU calculator is the OCN one made by Phaedrus.
Seasonic SS-660XP2 if price is no object.
Fully modular, Rock stable and highly efficient, if I was building now that's probably what I would get
HardOCP's GTX 980 test system, reasonably similar to yours (3770k @ 4.8Ghz) pulled 312W from the wall under full load.
If price is an object, the Rosewill Capstone 550W is on both newegg and amazon for $70, the XFX Core Edition 550W for $50 at the moment, or even the Corsair CX500 500W for $30 after rebate on newegg.
Just eyeballing your system I would have said 500W. USB, hard drives, ram, and fans don't have any significant effect unless you have dozens of them.
I'd probably throw a 650 in there just so you can go SLI down the road. You say no plans, but plans change.
