More than 7 USB HUB?
TheGeekFreek
Ok, so it Seems that 14 USB ports are not enough.. Not to mention, its hard keeping em all in one place.. does anyone know where I can find a USB hub with 20+?
Or can I hook up 7x 7 port USB hubs to a single USB hub?
I think that MIGHT be enough...
-Evil Juggalo
I don't know if this will work or not, but try plugging one of the hubs into the port of another hub.
Each USB controller can host up to 127 devices by chaining together multiple hubs. You just have to be sure that chained hubs are capable of supplying the power that your devices will need (don't chain more than two unpowered hubs together or plug all devices into powered hubs are some basic rules).
You can daisy chain the hubs together, so by plugging 7 x 7-port hubs into one 7-port hub which is plugged into your mobo you could have 49 usb ports. Note that the bandwidth is shared between all the devices though, so don't try hooking up 49 hard drives and then trying to read/write from them all at the same time.
If you need 20 ports, chances are you are connecting a few devices where some of them are identical (eg 3 printers or cameras, all the same model). A lesson I learned at work is to label the ports and cables. That way if you disconnect everything, you can reconnect them the same way later and your software won't become confused which printer or camera is which.
Some software identifies USB devices by the vendor ID and serial number, and some others by vendor ID only.
Daisy-chanining self-powered USB hubs should do the trick. Lots of 5V bricks hanging around because of that, though. If you feel up to it, go find a 4 or 5A 5V brick and wire it to all the hubs, only one brick that way. ;)
