more than 512mb ram worth it?
Gene126
I was thinking about going from 512 to 1024mb of ram. I am running Windows XP and always using multiple programs.
Do you think its worth the money or is 512 enough for XP?
for some of the new games you will see an improvement. I personally think its a good upgrade. I would not run my computer with any less then 512. I say do it
I've had games use 700+ MB of memory, and I absolutely loath virtual memory. We can't answer the question for you. You need to take a look at what you do with your PC, your current memory usage and make a decision.
depends on what u play, most FPS's barelyu take up your 512mb.
but if you play a lot of MMPORGS they'll definatly want 1gb.
I noticed a big difference between 512 and 768, then I got 1 gb, and didn't notice a huge difference between that and 768, but if your budget allows, go for it : )
if you play bf1942 then yes, get some.
when i was on 512 if i pressed esc to take me to main menu it would take so frigging long, about 10 seconds or more
with 1gig it takes me about 2 seconds, and thats with alot of stuff running in background while i game (virus scanner, mirc, kb/joystick software, etc...)
i think its worth it, but in the end its a matter of personal preference and what you really use your pc for. for gaming/cad and things like that you might need it.
I dont play a lot of games, just occasionally. I guess thats probably the only time I would really benefit.
What about video encoding, does that use a lot of ram or is it mostly CPU intensive?
The only game I play a lot is Madden 2004. I play bf1942 sometimes, mostly network multi.
How is madden on ram?
video encoding is mostly ram, ur gonna want the 1 gig
Ive been looking at a few different dimms.
Corsair PC3200 LL is listed as 2-3-2-6 timing
OCZ PC3200 EL is listed as 2-2-3-6 timing
the ram currenty in my system Hyper X 3200 Dual channel is listed as 2-3-2-6
What is the difference between the corsair and ocz timings?
I always thought it was pointless to have a gig of ram, but when I upgraded my AMD rig from 512 to 1024, I noticed the difference (especially in Battlefield 1942). It was like night and day with the games I play. I say go for it :D
yea, definilty on BF1942 it makes a huge difference. I'd imagine if you play HALO on PC it would too, both are tremendous resource(spelling anyone?) hogs.
yeh, get that ram, espessialy if you run antivirus, and firewall, etc on the backround. when i had 192mb ram and upgraded it 256, I saw a big ass difference.
Yeah, sounds like an upgrade would be worth while.
Now I just have to decide what to get.
I have GA-N7400-L motherboard with a Barton 2600+.
I currently have 2x256 Hyper X PC3200.
Would it be better to add 2x256 to my remaining slots or just go for 1x512 ?
Is it alright to mix brands, could I add corsair even though I have kingston right now?
Think I would notice a difference just adding 256 or would I have to add 512 to get any benefit?
Grab 2x512 pc-3200 crucial xms at newegg, that's what I would do personally.
brands to look at are:
mushkin
corsair
kingston
crucial
other than that, id stary away from. my personal suggestion would be corsair xms series pc3200 ddr400 ram. 2x512
I would like to keep using the 2x256 that I have right now. I probably wouldnt be able to sell is for very much.
I understand 2x512 is the idea situation for 1024mb setup but that would cost a lot for me to get since I already have 2x256
I'd certainly go for it in Battlefield. My old system has a gig of RAM, and my new one only has 512. I find myself going to the old system to play Battlefield.
I say if you have the money for it go ahead. When you say Multiple programs, which ones. If they are any type of graphics then I say Yes.
