More Terminal Services/Remote Desktop ?'s
fusionrs
I have a box running Windows XP Home. Does home allow for Remote Desktop? Also I am trying to stream some audio...Just Mp3's going like this. Remote desktop from my main machine...to server...then through the server remoting back to main machine and trying to play mp3's through a mapped network drive. Possible? Thanks for the input.
XP home can not do terminal services, but you can use some thing like Ultr@VNC to do remote desktop.
I am a little confused by your music question.
I have one more ?. Lets say I connect to my server from work. Then I want to transfer some documents from the server to the computer I am currently on. I tried to copy and paste, drag and drop didn't work. How do I do it? Thanks
Found it sweet!
How to Gain Access to Local Files
You can gain access to your disk drives on the local computer during a Remote Desktop session. You can redirect the local disk drives, including the hard disk drives, CD-ROM disk drives, floppy disk drives, and mapped network disk drives so that you can transfer files between the local host and the remote computer in the same way that you copy files from a network share. You can use Microsoft Windows Explorer to view the disk drives and files for each redirected disk drive. Alternatively, you can view the files for each redirected disk drive in My Computer. The drives are displayed as "drive_letter on terminal_server_client_name" in both Windows Explorer and My Computer.
To view the disk drives and files for the redirected disk drive:
Click Start, point to All Programs (or Programs), point to Accessories, point to Communications, and then click Remote Desktop Connection.
Click Options, and then click the Local Resources tab.
Click Disk Drives, and then click Connect.
