More Power Switches
is this...
capable of beeing the power switch for the whole comp..if not is there any other thing i could use
What the hell is that thing? All you need for a power switch is momentary contact. Any switch or button that is momentary will work as a power switch.
that looks like the rheobus/fan control board for an H-L 2 case i've seen somewhere...
any momentary switch will work go to ratshack and buy one for like a dollar
edit: Basically answer is no.. on-off switches and potentiometers or whatever those are won't work. You really need a momentary switch if you do not want to make a circuit to convert the one switch and it wouldn't make much sense to have a twist knob on a power button.
