adamadekat
- Aug 12, 2004
So I just got shot like 7 times by an archer and now I don't know how to remove the arrows that are stuck in my body...how do they go away or how do I remove them???
I think they will ramdomly dissapear over time... or if you save/reload... How would repairing your armor remove an arrow sticking threw your eye?Eagle156 said:I think you repair your armor to get rid of the arrows.
Niksa said:You can also edit the ini and reduce the amount of time arrows stay, but generally they disappear after an hour or so (real time). I can't remember the default setting but I'm pretty sure it's not longer than an hour.
