Ok, so I'm trying to follow this guide: http://www.sislands.com/coin70/week5/onChange.htm
The problem I'm having is that it only populates the listbox with the first letter of the array name. If I alert the variable used to do an eval(Monitor), it will alert me with Monitor, and the lsitbox will be populated with 'M'.
This is the code that I've written:
Edit: Oh, and before all that:
Code:
[SIZE=3]function tablelist(PC) {[/SIZE]
[SIZE=3]var Select1 = document.add.type;[/SIZE]
[SIZE=3] var _Array = eval(PC);[/SIZE]
[SIZE=3] setOptionText(Select1, _Array);[/SIZE]
[SIZE=3] alert(_Array);[/SIZE]
[SIZE=3]}[/SIZE]
[SIZE=3]function setOptionText(Select1, _Array)[/SIZE]
[SIZE=3]{ [/SIZE]
[SIZE=3] for (loop = 0; loop < Select1.options.length; loop++) {[/SIZE]
[SIZE=3] Select1.options[loop].text = _Array[loop];[/SIZE]
[SIZE=3] }[/SIZE]
[SIZE=3]}[/SIZE]
Code:
var PC = new Array("Desktop", "Laptop")
