I'll probably get a shuttle since I like the smaller look. If I put three hard drives, will a couple of hard drive cooler fans fit also? I'm worried about the heat so I'm going to run it open case.
Ive got three hard drives in my Sn45g plus a dvd burner. I would not recommend it though as there is almost no airflow over the ram and its a very tight squeeze. I used a few pieces of carbon fiber I had laying around to make brackets to attach the drive under the drive cage. So far no problems...so far.
