More FPS
HighwayAssassins
I was just wondering, i saw an option in bios to up the power to the AGP, and i was wondering of that could maybe squeeze out a few more FPS out of my Radeon 9600 XT?
if you are OCing your CPU, then sometimes you may need more AGP voltage. depending on your gear <mobo mostly> you will have to up the AGP voltage, but for a default rig, the default voltage will suffice and you usually wont see any difference in performance with more voltage unless you overclock the video card.
C
adjusting the AGP voltage wont affect your video cards OC.
It just stabilizes the bus at higher speeds.
