Got a friend with a Diamond Multimedia Monster MX300 ( AU8830a2 ) sound card who has a problem with audio dropping out in XP. Audio generally works for a few minutes from startup but then cuts out, returning only upon restart. I've seen references to problems with these cards on VIA boards (and this is in a VIA board) but haven't been able to ferret out a fix as many links related to the issue seem to be dead or circular. The only info I found here was http://hardforum.com/showthread.php?t=761585 but that seems to suffer from dead links as well.
Anyone else here know what the fix was? Or a driver that doesn't have this problem? Sound works fine from the onboard audio if enabled, though it's a bit rough by comparison.
