If I use a WRAP board that has 2 mini-PCI slots, can I put 2 wireless adapters in it and have them both act as access points bridged to a single LAN port? My purpose in this is to use (3) 120 deg sector antennas with each antenna connected to one wireless card spread over 2 WRAP based access points.
I found the Ubiquiti Super Range 2 SR2 400mw 802.11b/g miniPCI adapter that I think will give me quite a bit of power on each antenna.
The antenna I'm looking at is the Vertically Pol 16.4 dBi 120 deg Sector from fab-corp.com
What are your opinions? The reason I chose sectors over an omni is that there seems to be alot of interference around here. I need to cover a large area and need the best signals possible.
If you have any better ideas let me know. I'm trying to keep this on a reasonable budget, so no need to mention a canopy system or similar unless you can tell me where to get them for a steal.
Thanks.
![pac17vsec.jpg](http://fab-corp.com/pac17vsec.jpg)
Thanks.
