monochromatic laser printer vs color laser printer...
ar09
what do you guys think about buying a b&w laser printer instead of a color laser printer?
printing pics or printing graphs or printing stick figures or what
if you do mainly word doc printing(aka b&w is fine), then get a b&w laser... for color printing, go to the local library/kinkos/staples, or maintain a cheap inkjet for color
laser b&w printing can be done at 1cent per page or lower
if you do mainly "word doc" printing(aka b&w is fine), then get a b&w laser... for color printing, go to the local library/kinkos/staples, or maintain a cheap inkjet for color
i wanted to buy a cheap color laser printer but they all have problems so i was thinking on buying a b&w one. good choice, for printing online receipts stuff i buy?
thanks
So far, I have had good luck with the dell 2130cn and the hp3700n. Both have cheap 3rd party ink available.
The color print quality is nowhere near as good as a dye sub or top end inkjet, though.
high yield inkjet might better pick. laser printers use a large amount of power. if you are doing less than 500 pages a month.
