The Gateway FPD2275W and 2475W both have 1:1 scaling. I just bought the 2275W today; and it's great, no dead pixels, and I've been playing my PS2 on it most of the day.
In the menu you can pick the video settings, and then you can pick the scaling options and 1:1 can be chosen from there.
The NEC 20WMGX2 doesn't have scaling options over DVI except in DVI-HD mode, which is only useful for external devices. Even then, it doesn't scale 1080p or 480p properly over DVI. 1080p is stretched to fill the screen with no scaling options, and 480p has a 3:2 aspect ratio.Mansize_tissue said:I believe the NEC 20W(M)GX2 also has the ability to utilise 1:1 pixel mapping through the OSD, too.
