Monitoring windows F@H clients over a network.
hungryduck
Is it possible to use FAHmon to monitor all the computers in my house that are folding, instead of just the one I run FAHmon on? Or is there another program to do this....these are all winxp machines.
The FAQ is your friend!
Here is the relevant post, if I am not mistaken.
EMIII will do this. Simply share the F@H folders on each other machine, and be sure to grant both read and write permissions on the share. Then add the boxes to EMIII, and you're done.
FahMon does it perfectly (I use it to monitor my 6 in house comps). Just share the F@H folder and then FahMon can connect to the folders and monitor them.
This is what I do and it works pretty good for me.
awesome! thanks a bunch....this folding thing is really cool....time to go borg some more!
so what do i do when my PC's are distirbuted over the intArweb?
You can put EM3 on each box, and tell it to upload its status to a web server (you provide). I don't think EM3 can currently download/parse those uploaded pages, but at least you can see them from any web-able computer.
