Monitoring temps - Speed fan question
rgratto2
Is there any standard mapping for what "temp1", "temp2", etc are? My temp 1 seems to be a bogus value (127 C??), but i figure its something worth looking into! The core temp is 35 C, and the gpu looks to be idling at 61 C.
i heard sum one say that the 125.c one is a temp sensor that isnt actualy there so dont worry
Hmm i wasnt especially worried, because a temp that high seems ridiculous, and i was trying to check my temps using various other programs as well...
