Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Does speed fan report everything okay? I've used MBM5 which takes some messing and always seems to read differently to Asus Probe. Then there's Everest which is good but switches the CPU and AUX temperature values...
It's ok, but it doesn't give specific temps, it just lists temp1, temp2, temp3, temp4, etc. The highest temp is usually the CPU temp, and the temp that rises proportionally with the CPU temp seems to be the chipset temp. It is all pretty logical.
i have a dfi ut ultra-d mobo. anyone know how to setup mbm5 so i can use it with tthis mobo. i tried setting it up, but as soon as i started selecting the sensors it locked up my system..... every time.
