Gigabyte uses ITE Super I/O chips, which means you'll need the it87 module and probably a bunch of hacks for newish motherboards.
It's impossible to give advice without output from relevant programs such as sensors-detect, lspci, and lsmod. What does "sensors" report? Can you at least read your CPU temps? I assume you have the "k10temp" module loaded.
Try searching the GitHub issues for terms such as "gigabyte": https://github.com/lm-sensors/lm-sensors/issues/
output from sensors
k10temp-pci-00c3
Adapter: PCI adapter
Tctl: +42.9°C
Tdie: +42.9°C
Tccd1: +43.8°C
acpitz-acpi-0
Adapter: ACPI interface
temp1: +16.8°C (crit = +20.8°C)
temp2: +16.8°C (crit = +20.8°C)
gigabyte_wmi-virtual-0
Adapter: Virtual device
temp1: +31.0°C
temp2: +32.0°C
temp3: +42.0°C
temp4: +34.0°C
temp5: +37.0°C
temp6: +44.0°C
nvme-pci-0100
Composite: +41.9°C (low = -273.1°C, high = +84.8°C)
(crit = +84.8°C)
Sensor 1: +41.9°C (low = -273.1°C, high = +65261.8°C)
Sensor 2: +40.9°C (low = -273.1°C, high = +65261.8°C)
lspci
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Starship/Matisse IOMMU
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge
00:01.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:03.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge
00:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:05.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:07.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:07.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
00:08.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
00:08.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 61)
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 3
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 7
01:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983
02:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse Switch Upstream
03:04.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge
03:08.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge
03:09.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge
03:0a.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge
04:00.0 Ethernet controller: Intel Corporation I211 Gigabit Network Connection (rev 03)
05:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
05:00.1 USB controller: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller
05:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller
06:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 51)
07:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 51)
08:00.0 VGA compatible controller: NVIDIA Corporation TU104 [GeForce RTX 2060] (rev a1)
08:00.1 Audio device: NVIDIA Corporation TU104 HD Audio Controller (rev a1)
08:00.2 USB controller: NVIDIA Corporation TU104 USB 3.1 Host Controller (rev a1)
08:00.3 Serial bus controller [0c80]: NVIDIA Corporation TU104 USB Type-C UCSI Controller (rev a1)
09:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function
0a:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
0a:00.1 Encryption controller: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Cryptographic Coprocessor PSPCPP
0a:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller
0a:00.4 Audio device: Advanced Micro Devices, Inc. [AMD] Starship/Matisse HD Audio Controller
0b:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 51)
0c:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 51)
lsmod
Module Size Used by
snd_seq_dummy 16384 0
snd_seq_midi 20480 0
snd_seq_midi_event 16384 1 snd_seq_midi
snd_seq 73728 3 snd_seq_midi,snd_seq_midi_event,snd_seq_dummy
snd_hrtimer 16384 0
hwmon_vid 16384 0
btrfs 1388544 0
blake2b_generic 20480 0
xor 24576 1 btrfs
zstd_compress 176128 1 btrfs
raid6_pq 114688 1 btrfs
ufs 81920 0
qnx4 16384 0
hfsplus 110592 0
hfs 61440 0
minix 36864 0
ntfs 106496 0
msdos 20480 0
jfs 188416 0
xfs 1515520 0
cpuid 16384 0
uas 28672 0
usb_storage 73728 1 uas
xt_conntrack 16384 1
xt_MASQUERADE 20480 1
nf_conntrack_netlink 49152 0
nfnetlink 20480 2 nf_conntrack_netlink
xfrm_user 36864 1
xfrm_algo 16384 1 xfrm_user
xt_addrtype 16384 2
iptable_nat 16384 1
nf_nat 49152 2 iptable_nat,xt_MASQUERADE
nf_conntrack 147456 4 xt_conntrack,nf_nat,nf_conntrack_netlink,xt_MASQUERADE
nf_defrag_ipv6 24576 1 nf_conntrack
nf_defrag_ipv4 16384 1 nf_conntrack
libcrc32c 16384 4 nf_conntrack,nf_nat,btrfs,xfs
br_netfilter 28672 0
bridge 266240 1 br_netfilter
stp 16384 1 bridge
llc 16384 2 bridge,stp
md4 16384 0
cmac 16384 1
nls_utf8 16384 7
cifs 1167360 2
libarc4 16384 1 cifs
fscache 380928 1 cifs
netfs 45056 1 fscache
libdes 24576 1 cifs
vboxnetadp 28672 0
vboxnetflt 28672 0
aufs 258048 0
vboxdrv 524288 3 vboxnetadp,vboxnetflt
ip6table_filter 16384 0
ip6_tables 32768 1 ip6table_filter
iptable_filter 16384 1
bpfilter 16384 0
overlay 126976 0
binfmt_misc 24576 1
intel_rapl_msr 20480 0
intel_rapl_common 24576 1 intel_rapl_msr
nvidia_uvm 1036288 0
nvidia_drm 61440 14
nvidia_modeset 1200128 24 nvidia_drm
edac_mce_amd 32768 0
snd_hda_codec_realtek 147456 1
kvm_amd 118784 0
snd_hda_codec_generic 81920 1 snd_hda_codec_realtek
ledtrig_audio 16384 1 snd_hda_codec_generic
nls_iso8859_1 16384 1
nvidia 35319808 1641 nvidia_uvm,nvidia_modeset
snd_hda_codec_hdmi 61440 1
snd_usb_audio 299008 1
kvm 864256 1 kvm_amd
snd_hda_intel 53248 8
snd_intel_dspcfg 28672 1 snd_hda_intel
snd_intel_sdw_acpi 20480 1 snd_intel_dspcfg
snd_hda_codec 147456 4 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec_realtek
snd_usbmidi_lib 36864 1 snd_usb_audio
crct10dif_pclmul 16384 1
snd_hda_core 94208 5 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek
ghash_clmulni_intel 16384 0
snd_hwdep 16384 2 snd_usb_audio,snd_hda_codec
aesni_intel 376832 1
snd_pcm 114688 5 snd_hda_codec_hdmi,snd_hda_intel,snd_usb_audio,snd_hda_codec,snd_hda_core
crypto_simd 16384 1 aesni_intel
cryptd 24576 2 crypto_simd,ghash_clmulni_intel
rapl 20480 0
wmi_bmof 16384 0
snd_rawmidi 36864 2 snd_seq_midi,snd_usbmidi_lib
uvcvideo 106496 0
efi_pstore 16384 0
videobuf2_vmalloc 20480 1 uvcvideo
videobuf2_memops 20480 1 videobuf2_vmalloc
snd_seq_device 16384 3 snd_seq,snd_seq_midi,snd_rawmidi
gigabyte_wmi 20480 0
drm_kms_helper 253952 1 nvidia_drm
videobuf2_v4l2 32768 1 uvcvideo
snd_timer 40960 3 snd_seq,snd_hrtimer,snd_pcm
videobuf2_common 61440 4 videobuf2_vmalloc,videobuf2_v4l2,uvcvideo,videobuf2_memops
ucsi_ccg 20480 0
cec 53248 1 drm_kms_helper
videodev 249856 3 videobuf2_v4l2,uvcvideo,videobuf2_common
typec_ucsi 40960 1 ucsi_ccg
snd 94208 31 snd_hda_codec_generic,snd_seq,snd_seq_device,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_usb_audio,snd_usbmidi_lib,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_pcm,snd_rawmidi
rc_core 61440 1 cec
fb_sys_fops 16384 1 drm_kms_helper
joydev 28672 0
syscopyarea 16384 1 drm_kms_helper
typec 57344 1 typec_ucsi
input_leds 16384 0
sysfillrect 16384 1 drm_kms_helper
k10temp 16384 0
ccp 98304 1 kvm_amd
sysimgblt 16384 1 drm_kms_helper
mc 57344 5 videodev,snd_usb_audio,videobuf2_v4l2,uvcvideo,videobuf2_common
soundcore 16384 1 snd
mac_hid 16384 0
sch_fq_codel 20480 3
cuse 16384 3
ipmi_devintf 20480 0
ipmi_msghandler 114688 1 ipmi_devintf
msr 16384 0
parport_pc 45056 0
ppdev 24576 0
lp 20480 0
drm 557056 18 drm_kms_helper,nvidia,nvidia_drm
parport 65536 3 parport_pc,lp,ppdev
ip_tables 32768 2 iptable_filter,iptable_nat
x_tables 49152 8 ip6table_filter,xt_conntrack,iptable_filter,xt_addrtype,ip6_tables,ip_tables,iptable_nat,xt_MASQUERADE
autofs4 45056 2
hid_jabra 16384 0
hid_generic 16384 0
usbhid 57344 0
hid 139264 3 usbhid,hid_generic,hid_jabra
crc32_pclmul 16384 0
igb 229376 0
nvme 49152 4
ahci 40960 2
i2c_algo_bit 16384 1 igb
xhci_pci 24576 0
i2c_piix4 28672 0
i2c_nvidia_gpu 16384 0
libahci 36864 1 ahci
dca 16384 1 igb
xhci_pci_renesas 20480 1 xhci_pci
nvme_core 126976 6 nvme
wmi 32768 2 gigabyte_wmi,wmi_bmof
