Monitor without aggressive AG coating
I am looking for a monitor with no aggressive AG coating. I already had to return the Dell UltraSharp U2311H due to its coating. I guess IPS panels won't be an option then.
The monitor should nevertheless be matte, I just can't stand glossy screens.
I mostly use the monitor for gaming and surfing the web.
It should be 23-24 inch.
I already tried the BenQ XL2410T, but it had such bad backlight bleeding - had to return it.
Its AG coating was nice though.
Or Eizo FS2332 / EV2335 which seems to also have PLS-panels, just like the S24A850.
The Samsung S24A850 doesn't have agressivve AG, but then again it has agressive backlight bleed.
It's supposed to have strong backlight bleeding.
Aggressive anti-glare is the nature of some panels, backlight bleed on the other hand is because of poor quality construction/ materials/ quality control, so there is a chance you can get one without backlight bleed.
The chance of not getting a U2412M for example, with aggressive anti-glare is 0, it is sometimes worth gambling with a screen to see if it comes without the backlight bleed, although IMO the 24" Samsung is quite expensive for what it is :p
Right, it's quite expensive :(. For over 300 € I think I could expect a monitor with little backlight bleeding.
Isn't there any TN-panel with a good AG coating?
