Hi All,
My main workstation is DVI.
I'm regularly working on a number of different PCs. Most with VGA only and some with DVI.
I have an Iogear DVI KVM. According to iogear you can use a VGA to DVI adapter if the workstation doesn't have a DVI port. I have this adapter. Unfortunately, it isn't working. My monitor just says "unable to display this mode" when I try to use VGA.
I think the problem is that my monitor is DVI-D (digital only) while I need one that is DVI-I (Analog and digital). When the KVM is on a PC with DVI it will use the digital portion of the DVI-I and when it's on a PC with VGA it should use the analog.
I have no problems with purchasing a new monitor, but if I'm going to buy a new one it might as well support HDCP. Does anyone know of a LCD monitor that has DVI-I connectors AND supports HDCP?
I'd like to have something larger than 20" and a minimum of WSXGA+ resolution. (1680x1050)
I was looking at the HP LP2465 and it has dual DVI-I ports, but no HDCP support.
Thanks!!
Riley
Thanks!!
Riley
