Monitor warms/flickers up
Croak3
Hello,
I have a couple tear old Samsung 20.1 flat screen monitor.
Lately, when coming out of slumber mode it takes 1- to 30 seconds to flicker back to life.
Any ideas appreciated
Regards, Croak
Yes, I do have an idea. I had the same problem on my samsung 20.1'. It means your CFL inside the monitor is dying. It'll eventually die and you either have 2 options: (1) repair it and (2) use your warrenty.
Thanks for the ...idea,
Monitor is undoubtedly out of warranty. E-bay purchase anyway.
CFL…um…compact florescent …?? Available? Are these costly? More likely that then power supply?
Regards, croak
Actually, did you mean CCFL? it looks like there allover for $10-$15.
Yeah I meant CCFL. I don't recommend servicing it yourself if you don't know what your doing. If you must, there are guides out there that'll help you.
