Monitor Video card stats while gaming
MrGuvernment
Curious if such a program exist like task manager for windows, bu something that can tell me stats of my video card while it is in use.. like how much Vram is being used and such?
want to do some tweaking on some games and see if it effects it much at all.
You can do this with Rivatuner.
You go to the hardware monitoring section and right-click on one of the graphs (GPU core temp, etc) and you click Manage Plugins. One of the options there has a feature for telling how much VRAM is being used, you have to click that and go back to the graph. Then you can right-click on the graph and click on "Setup" and then look down until you see "Show OSD statistics" then you would see another Rivatuner system tray icon with a green arrow on it which is responsible for showing stats on the screen when you run a D3D/OGL app. You'll see what I mean.
If you have an ati card ati tray tools has it (I think it only works for ati not sure though)
yeah, those are definitely the way to go.. This little sticker I took off my fishtank that changes color with temp stopped responding above 105C :eek:
