Okay here's the situation. I have a Hitachi CM721F 19" monitor. I was previously using a leadtek gfti4400, on which any refresh rate besides 60hrz or 100hrz would cause image jitter. I lived with this as 100hrz is great. I recently upgraded to a sapphire 9800pro, and now only 60hrz is a stable refresh rate, all others including 100hrz cause image jittering. I thought maybe it was the 120mm vantec stealth side blowhole causing EMI, but i disabled the fan and the image still jitters unless the monitor is at 60hrz.
Can anyone help me? 60hrz is far too low my eyes are starting to bleed.
P.S.- Tried both ATI Cat 3.10's and Omega 3.10's, image jitter problem exists with both. I'm running a p4 1.8a on an Abit IT7, agp is set to 66, enermax 350watt psu (not the cause, system is no where near needing psu upgrade).
Ideas?
Ideas?
