Monitor Upgrade
DarthKhan
Hello. I have a VZ249 monitor. It is a Full HD 24 inch IPS 60hz monitor. I am quite satisfied with it but at the same time i wouldnt mind a bigger screen and better resolution.
So is there a monitor that is pretty much the same but is 27 inch 2560x1440p IPS 60hz ? Its not going to be used for any hardcore gaming, mainly just for like 70 percent web surfing and 30 percent casual gaming, so the 60hz is just right for me.
I have eyed the MX27AQ, but apparently it is no longer available, so I am now eyeing the MZ27AQ, but I would love if you could give me some more options and I will decide based on price and availability. Thanks.
I have the Acer Nitro XV272U. It's slightly more expensive than the MZ27AQ, but has better ergonomics (stand) and has 144hz. I am very pleased with it.
There are tons of high quality 27" 1440 and 4K monitors out there with excellent picture quality. Best thing to do would be check out some review sites like TFT Central. There are tons of reviews out there online and on YouTube. Find the ones that review the best and then out of those find the ones that fit your budget.
