Monitor Upgrade: Another 24" or an Extra two 20"?
Jacez44
I currently have a single 2407WFP-HC.
I can either afford to buy two 2007FP's or a 2408WFP.
If I buy the 20 inchers I'll place them on either side of the main monitor. If I buy the second 24 incher, I'll have to somehow have two main monitors, which will probably make gaming a bit strange. Also, the two 20 inchers will fit perfectly when I upgrade to the 3008WFP in about a year, and the two 24 inchers will not look too good with it.
What do you think?
Id take the 2x 20in especially if you are set to upgrade to a 3008WFP.
