monitor / tv setup
andywaller
I have a 24 inch monitor and a 40 inch tv, both mountable. Ive seen youtubers with monitors and then a tv above it tilted towards them. I cant wall mount. what do i need to buy that can hold the tv and the monitor?
Most desktop mounts are rated by weight, not necessarily size. They often state size (such as 24" or 27"), but that is often just a general guideline and in regards to multiple monitor mounts, the general max size for the monitors to align and fit on the mount. The number to watch, as noted previously, is the weight. And for desktop mounts, that's about 20-24 lbs. I've not seen any rated higher than that. At which point your only option would be a custom built mount or in the case of a TV, wall mounting.
Search Amazon to get some ideas. You may be able to get by to two separate mounts.
