Monitor Tuning
Deception
i just got a new Benq fp937s 19inch lcd monitor and wondering if there are programs out there to help you tune your monitor?
Displaymate is a good program to use to setup your new LCD. Nokia also makes a utility called NTEST. Just go to google and do a search for it. I personally find using a hardware solution is the way to go. I use the colorvision spyder with is a USB device to set up your new LCD Perfectly.
