Monitor troubles
Cyper
I'm having some monitor problems, doesn't surprise me because it's a cheap KDS CRT however I'm wanting to check to see if there is some sort of fix for it.
Basically what's happening is when I open anything that has bright colors, mostly white like google.com or explorer for instance it gets this wavy distortion effect in the top and bottom corners of the screen, even more severe in the tops.
I can smack the side of the monitor and it goes away, or open a darker window and it instantly goes away.
Sounds like something is loose inside or something, but I'm not sure anyone got any ideas?
I was planning on buying a new monitor anyhow but I would like for this one to not be completely worthless as I was planning on using it on another system.
