Monitor text sharpness.
sblantipodi
Hi all,
I have bought two Eizo S2433WFS-BK, 24", S-PVA.
What to say, exceptional monitors but I have a questions.
I noticed on both monitors that text isn't perfectly sharp everywhere on the panel.
Is this normal?
Changing the phase help a little but mostly translate the problem on another screen area.
For example, with phase set to 12, I notice a little of blur on text on the border left and right of the panel. If I set the phase to 45 I notice that the borders is really sharp but the central part of the panel is blurred.
Is there a way to correct this "problem"?
At the moment I can test this monitors only with my laptop using VGA since I haven't got a desktop here, do you think that this may be the cause of my problem?
I have only ever witnessed that on a VGA connection.
I've seen the same problem when using a VGA connection.
A switch to DVI or HDMI will very likely eliminate the issue.
I runned the autoadjustment features of my monitor after 30 minutes.
It setted the phases to 20, now my monitors are perfect.
Excellent, thanks for the feedback.
