monitor stopped working on new comp
Ryan711
Ok here is my problem, I recently built a computer and am waiting until I get paid until I buy a monitor. So i'm using the one from my old hp from 2001. The monitor model is mx70. So I plug it in and it works for the first couple of days.
I overclocked my graphics card(a 6800LE unlocked 16, 6) using rivatuner from 300/700 to 390/900. I did it on both 2d/3d tabs. So I stress tested it with that program thats really hard to remember, rtddhesj, or something like that. Then I ran 3dmark 05 a few times, all was good.
Then I was playing the AOE 3 demo and was changing graphical options and turned on vsync. Well when I did my monitor went into the power saving mode which means it is on but the screen is black and the light changed from green to orange. Oh and also the power button on the front stopped working, it only let me turn it on from the switch on the back.
I tried to fix it but no luck, so I plugged it into the other computer and it works just fine. I tried again today and it worked, I saw it turned on and left it, but when I came back it was the same problem.
Then after messing with it for a litle bit I unplugged the graphics card molex and took it out of the agp slot and put it back in, turned it on and it worked again, so did the power button. After it was working for a little bit I decided to mess with the msi software oc'ing program to see how high my ram could go. Well it froze at about 220mhz.
I reset using the reset button and it go to the msi boot screen and it froze there. So I turned it off and same problem. Haven't gotten it to work since. Any ideas as to why it isnt working. Here are my specs:
neo 2 plat
3200+ venice
6800LE unlocked to 16, 6
480w Antec true power II powersupply.
